Mike_Arcari
I would check the pdf file itself in case its corrupted as this sometimes happens for whatever reason
If you are getting the same problem with all pdf's then it may be a problem with Est as there should be no reason why it wont import
try importing something else like a dwg or a dxf to see if that works and it may indicate where the issue lies either with the file or the software
