269 Views, 1 Reply
MISSING ITEM FOLDER
My company is in the process of trying out the new trial version of Camduct. In the previous version there was an item folder for architectural parts or flat patterns to make rings and bolt hole patterns but I'm not able to find this in the new trial version. Does anyone know where to find these?
I might be mistaken, but all the items in your folder "item folder" are custom and made from CID patterns. There were a few OOTB patterns and parts available, but in the end, we ended up making our own custom parts and pieces. If you hit control + shift + "C", it will give you a command prompt within camduct to make all the patterns available. Attached is a pattern list for your use. Alternatively, you can do the same in CADMep2019 fabrication by typing "makepat", entering the CID number you want and creating your part. Hope this helps
