- Mute
- Permalink
- Report
Hi Donald
Further to your email response below. Have had the problem again recently.
Just to let you know
Item2. Try toggling Dynamic Input (F12)
Worked.
Many Thanks
Mark
@donald.kunath wrote:
Hi @Anonymous
Thank you for your reply, unfortunately I was not able to view the snapshots you sent my way. While you locate and send those screen shots my way I have some items I would like you to test.
Note: the fist step is essential for CADmep to display the default Item information correctly. When testing the ToolTip the CADmep attacher should be removed from the item.
1. Go to AutoCAD Options > Display tab > Windows Elements section - disable the option "Show rollover ToolTips"
If still not displaying:
3. Issue the FORCETOOLTIP command
Please give the above a try and report back to me your findings.
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
