jdlandry504
293 Views, 3 Replies
IFCE in Fabrication CADmep 2019 produces a blank file
When i use the ifce command in Fabrication CADmep 2019, it produces a blank file.  My drawing has a building full of pipe.  I do have save graphics with drawing turned on.  Am i missing some setting?
Jason Landry
SM BIM-VDC Specialist
Bernhard
Look at the log file generated when importing the ifc into Navisworks.  My assumption would be there is errors during the import bringing nothing in.  You should see a line that says something like Elements created.  This should have a count if no errors were encountered.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Thanks for the help but for ifc's we are not using navisworks.  We are using solibri in this instance.
Jason Landry
Bernhard
Now that i think of it, i remember having issues starting in CADmep 2018 and ifc exports.  Can you go to 2017 or earlier version and see if it works.  I just did a test and exported from 2017 and then from 2018 and changed the file extenstion from ifc to txt.  The formatting is quite different.  2018/19 doesnt work in Naviswork (Not what you are using but i bet acts the same as Silibri) but 2017 does.
Nathan Chapman
