Hi @asherj_tmi, Thank you for reporting your case. Round ducts have a default value in their options set as Certified. Therefore, the takeoff dialog box does not show up every time. Press the right mouse on the rectangular duct icon, go to the properties, then options and there select the Certified box. After that you will be able to insert channels without any dialog window after each section. Let me know if that helped you?
