iabonce
334 Views, 1 Reply
Pipe Coupling ITM File
I downloaded content for pipe couplings up to 6". I had to add custom content to create sizes 8"-12". When I created the sizes the full coupling is not showing on the larger sizes. See attached images for how the couplings up to 6" look vs the 8"-12".
nathan.chapman
in reply to: iabonce
I would suspect the connector breakpoints for sizes 8-12 are not setup correctly or at all.  Here is a link that explains breakpoints. https://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/2....  If this doesn't work can you please send me the itm file.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
