artcaddept
in reply to: MOatman
Thanks for the reply. That is correct. Unfortunately, I am pigeonholed into having to access the command line from within a cod script.
For context, I am trying to create spool drawings that run a lisp file upon creation. Fabrication's "BSPOOL" command dialogue somewhat allows this, however, it will only specifically allow cod files. Not SCR or LSP files. I thought I could potentially get around that on the back side by specifying the LSP through the spool.ini file. However it still only looks for cods when they are being created.
I am currently running the LSP after they are finished creating through autoscript but would prefer if this could be done as each spool was made versus retroactively. Any ideas are greatly appreciated
