murali
201 Views, 0 Replies
Multiple AutoCAD instances created while ploting a new drawing through API call
https://www.keanw.com/2007/10/previewing-and-.html
I have used the code from above link to open a new drawing into the exisiting ACAD Application & convert it to PDF.While plotting to PDF, another instances of AutoCAD is created & destroyed (apart from the existing ACAD Application).It creates a new instance exactly while endding the plot( PlotEngine.EndPlot(null) ).
Note: I have used this code to convert a ACAD drawing with Fabrication(CADMep) item
Is there any solution to fix this?
