jmmiller,
Not to contradict JHoward, since I've heard he's pretty good at this stuff, but there is an approach that will work, however, your mileage will vary depending on scope. The process is tedious, so if you're trying to convert/print an entire system, it probably won't be worth your time, but if you only want a single part, give it a try.
Like JHoward said, Fabrication parts are surfaces, however proprietary; your goal is to get them into AutoCAD solids so you can export. Here's how to get there (many of the tools can only be seen on toolbars in the 3D modeling workspace:
  1. EXPLODE the Fabrication part. Result = a series of tangential 3D faces.
  2. CONVTOSURFACE. Result = a series of tangential AutoCAD surfaces.
  3. UNION. Result = A single AutoCAD surface, combined at the previously tangential edges. Note: if your edges aren't tangential, this step will give shotty results, and your solid won't turn out as expected.
  4. THICKEN. Result = A 3D solid. Note: the surfaces don't go away during conversion, you'll need to manually delete those.
  5. EXPORT. Use the regular AutoCAD export menu to create an STL.
See attached STL of what was previously a fabrication pipe, thickened to 0.1".
Hope it helps,
G
