- Mute
- Permalink
- Report
"Fabrication part" of cable trays customized fitting.
Can we prepare & use "fabrication part" of cable trays customized fitting in Revit (non-standard angle which supplier agreed to fabricate due to site condition).
If yes, anyone can provide a tutorial preparing new parts or modifying angles of existing parts.
- Mute
- Permalink
- Report
Copy one of the ITM content items that most closely resembles what you need (minus the angel). Edit the ITM in the Folders view of CADmep or ESTmep.
You'll want to remove the Angle field from the product list so that you can edit it upon placement based on what you need.
You may also want to remove thew "Rungs" quantity field from the product list as well so you can edit those as well. Any other items you want editable, make sure you remove from the product list.
You'll also want to edit the product list name so it more accurately reflects what's being used.
Here's a quick and dirty screencast....
Here's more info on creating content...
For better user support, go to XtraCAD.com which is the largest group of Fabrication users hangs out at. There's over a decade's worth of relevant posts there.
