- Mute
- Permalink
- Report
Hello @Anonymous
Thank you for the forum post and welcome!
I appreciate the screen shot you included per your forum post, that always helps for troubleshooting.
I have a couple of questions to ask you regarding your post.
1) Using you Autodesk Desktop Application, can you confirm that you are using the most recent version? Per the version on my machine I have the following: Version - 2018.0.0.F, Build - 3.06.844 (2018.3), this data can be found by typing appinfo into the command line in Fabrication CADmep
2) Unless I missed it was there a specific question that you are trying to have solved?
@Anonymous did an excellent job of walking through the screenshots you sent, and providing an explanation to what it is your seeing.
As you mentioned above, it looks like you have alot of duplicate services which can lead to some confusion in Fabrication CADmep, I would suggest you clean these up, or give them a different name.
Thank you and I look forward to your thoughts!
