398 Views, 3 Replies
Imperial unit, SS Sanitary Tube with Tri-Clamp Fittings
All,
Can anyone point me to a Building 3D Content for Imperial unit, SS Sanitary Tube with Tri-Clamp Fittings? I found metric and know it is in Plant 3D but am trying to implement Revit and CAD MEP Fabrication for design through Fabrication documents.
Also... Should we have a specific CAD MEP\Fabrication forum?  How many of you are trying to use this tool?
Bill
Tiana_Y
Hi @Anonymous,
Thanks for posting in the forum! This question may be better suited for our Fabrication CADmep Forum, which I added the think for. I can actually go ahead and move this over for you if you'd like?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
in reply to: Tiana_Y
Hi... Yes please feel free to move it.
Thank you,
Bill Henze
If you have the metric, you can try to convert it to Imperial or you'll want to make your own. Autodesk hasn't put any effort into content in several years..
You could try posting to XtraCAD.com and see if anyone there has it and is willing to share.
