584 Views, 4 Replies
Parts stretching when they shouldn't.....
Morning all
I've got an odd problem with parts stretching when using the grips to pull out knew sections of ductwork, and I don't know what has changed within the database to let this happen.
In the attached image, you can see the problem demonstrated on a circular VCD, but it happens on other pieces of equipment live fire dampers as well.
I used to be able to stretch the grips on the dampers and it would draw a new piece of ductwork, but now it just deforms the part.
Any help with this would be most appreciated as it's driving me mad.
Thanks very much
CADmep Fabrication 2018CADmep Fabrication 2018
MOatman
You can check the setting shown in the attachment.  In main database.
in reply to: MOatman
Thanks for the response. That check box is already ticked in my database....
pinaki.rajak
go to Edit Main Database >> Takeoff>> CAD Settings >> Go to Stretch Tab
and uncheck the "Restrict to use Items from the same Tab"
See the image below
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
in reply to: pinaki.rajak
PERFECT!! Thank you so much!
