donald.kunath
Hi @Anonymous
Thank you for your reply, unfortunately I was not able to view the snapshots you sent my way.  While you locate and send those screen shots my way I have some items I would like you to test.
Note: the fist step is essential for CADmep to display the default Item information correctly. When testing the ToolTip the CADmep attacher should be removed from the item.
1. Go to AutoCAD Options > Display tab >  Windows Elements section - disable the option "Show rollover ToolTips"
If still not displaying:
2. Try toggling Dynamic Input (F12)
3. Issue the FORCETOOLTIP command
Please give the above a try and report back to me your findings.
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
