Hi @Laurice.bergman
Thank you for the dwg I appreciate that greatly!  I was not able to locate the .IEZ file however.  I did receive the .IEZ you sent earlier but for some reason your export did not send the data that we were looking for.
In order to troubleshoot we need the HWS and STEAM .IEZ from the BUMLER - Hydronic service.  You can do this by typing exportsys into Fabrication CADmep and selecting BUMLER, refer to screen shot below.
When you did this last time, did you get any errors when you exported your service?  The service definition we received had no buttons for us to choose from as it typically should.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
