donald.kunath
in reply to: jona_little
Hello @jona_little
Thank you for your post and welcome to the community!
As far as the DIMBREAK command being improved to also affect CADmep Tags, this is not in the pipeline for improvements at this time, but I do see the value in your request.
I think your request would be a great suggestion for the Ideas page for Fabrication CADmep, if you post your idea and send me the link I can vote up your idea.
Fabrication Ideas
Per your Manual vs. Auto part of your question, my experts were not able to locate any other ways to complete this.  They do not see a way to make the DIMBREAK command default to one of its options, at this time it always requires that input, and they are not aware of another variable that would change it.
I also think this would be a good product feedback suggestion for Autodesk if you would like to fill out the form per this article.
Product Feedback
If you found my post addressed your issue, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
