donald.kunath
in reply to: mroble
Hello @mroble
Thank you for the screenshots and update!
You are almost there as far as draw order, in the button mapping tab or any window with Arrows you can select the item you would like to re-order, by selecting an up or down arrow - see below
I also included a youtube video that does a good job at explaining Service Setup in more depth.
If you found my post solved your question, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
