donald.kunath
in reply to: mroble
Hello @mroble
Thank you for your reply!
There isn’t a list of predefined button codes, what you are seeing as far as button mapping is by design.  In addition there is not a database that has all of these stored.
As you mentioned you can make the names up, or you can duplicate the names, but you will have to set the draw order and you would need to develop your own naming conventions.  If you use the same button code you will need set the lower and upper limits depending on your design.
If you found my post addressed your question, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
