donald.kunath
in reply to: mroble
Hi @mroble
No worries, there is always fires to put out and those come first!  Thanks for the update, I am glad we were able to get that going for you again.
As far as your follow up question, I would recommend if you couldn’t locate specifically Tee, enter this yourself as a value.  There are 3 different types of tee’s from the list but that doesn’t limit what you can enter as far as text.
I would recommend cross comparing your button mapping between your duplicated services so see how they line up, and if you are indeed missing anything small.
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
