- Mute
- Permalink
- Report
Hello @fernando.silveira.lima
I hope you are doing well and making lots of progress on your project.
I wanted to check in and see if you had a chance to review my last forum post, or if you have any additional questions for me?
I did some more research into your issue and this is what I could come up with at this time.
It is possible that you are not following the recommended workflow to achieve your results, what you would need to do within Fabrication CADmep is to navigate to BIM 360 tab (below is a link on how to troubleshoot if you do not see this tab) look to far left and above Coordination you will see a Glue button, this is where you export your Fab file to Glue successfully.
Hopefully this helps!
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
