mroble
in reply to: donald.kunath
I can confirm I'm using the latest version of Revit... 2018.3 I believe.
I need to check on the Fabrication though.
I'll get back to you really soon with more info on that.
Really quickly, my "workflow" I've been doing to try to make a Fab "library" that's company specific, was basically, duplicating existing Service Templates, and Services. And naming them something that's "my company name" prefixed. And at the same time, I've been populating a folder structure to be a "company centric" folder structure. So I can keep every ITM that's active in any company service and/or service template, it would be coming from our company folder structure.
Part of my reasoning is that this will allow me to download stuff, test it out first, then throw it into our "validated" folders, for company wide use.
The folders will be placed in a read-only area, and that's where everyone (except me) will be mapped to. Seeing as I'm the one that's going to evolve this library.
Like I said, I'll get back to you later regarding this, kind of neck deep in something right this minute, but I wanted to make sure you knew I saw this.
Thank you in advance!
