Hello @fernando.silveira.lima
Thank you for your post, and welcome to the Forum community!
Can you confirm that you are using the most updated version of 2019 Fabrication CADmep?  Follow the article below to determine if you are using the most up-to-date release of 2019 Fabrication CADmep.
Keep your Software Current
If your software is current, I would like to capture your workflow to help troubleshoot your issue, especially the "gives me an error saying it can't find the addin." message and details if possible.
Can you please do the following:
- A Screencast video (or a video from another screen recording utility) showing the steps you are going through.
 - A copy of the files used in the video (so that I can try reproducing the steps you are going through).
Can you please provide me with the file you are having issues with?  If you do not feel comfortable posting that information here, you are welcome to send the file to me in private.
Thank you for your help and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
