donald.kunath
in reply to: asherjoh
Hello @asherjoh
Thank you for your post!
At this time there is no way to resize the icons in the edit service template, I do however see the value in this suggestion as it is very hard to see those very small icons.  The best work-around I have is to drag the item into your template, study what it is, keep it if you like, otherwise right-click and choose Delete Button.
I would like to suggest you post this to our ideas page for Fabrication and I am confident other users on that platform will agree.
Fabrication Ideas
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
