mroble
618 Views, 1 Reply
Adding a "condition" to a button/service properties...
I'm in the process of cleaning up and creating a "company specific" set of services.
I have Ductile Iron Flanged and Mech joint all done, those were easy..
I created the company service for "buttweld/threaded".. It's easy enough, you place a button of a Buttweld elbow, then you go into that buttons' properties, you add a threaded elbow inside there.
You double click on the upper and lower limit area, you set the Buttweld elbow for Weld Condition, and it'll automatically show "greater than" 2" with no large restriction..
You click on the threaded, set that for Thread condition, and it will automatically set the upper restriction for "less than equal" to 2".
Now, to save myself some time, I decided to duplicate this service, and replace threaded with soldered fittings.
Now when I double click on a restrictions, it give me threaded, but not SOCKET... How can I add Socket? It's clearly coming from the service or something, since it's automatically setting the numbers in the restrictions
mroble
in reply to: mroble
Found it....
With the service TEMPLATE open, down at the bottom, you can right-click on a condition, and edit it.
I just editted Threaded to by Socket
