417 Views, 1 Reply
08-23-2018
11:39 AM
- Mute
- Permalink
- Report
08-23-2018
11:39 AM
How to compare Items in a Item List with Fabrication API?
List<Item> lstTrans = Job.Items.Where(x => x.CID == 2).ToList();
foreach (Item value in lstTrans)
//do stuff
} I use that to do stuff when needed.
But I want to be able to compare items within the list. I want to be able to find identical Item Numbers then make comparisons when needed.
e.g. if there are two Items with an Item number of 30, I want to then compare these two items to one another. I know what I need to do. I just want to know the easiest way to compare items in one list...
09-03-2018
03:40 AM
- Mute
- Permalink
- Report
09-03-2018
03:40 AM
How about (remember that the item number is actually a string, not an integer):
1. Get all item numbers of a known value of 1:
var items = Job.Items.Where(x => x.Number == "1").ToList();
2. Get all item numbers of a known value of 1 and where the CID is equal to 2:
var items = Job.Items.Where(x => x.Number == "1" && x.CID == 2).ToList();
3.
var items = Job.Items.Where(x => x.CID == 2).ToList();
foreach (Item value in items)
if (value.Number == "1")
// item number of 1
//do stuff
Does that help at all?
