jdlandry504
in reply to: MOatman
Our printers are set to PDF by default.  The only fix or work around we have found is to either do one at a time or print the multiple reports you need twice.  AutoCAD will print all the reports the second go round that you do it.  This is something that Autodesk needs to sort out and fix and its bothersome.  We are on the latest update of 2019 AutoCAD and CADmep.
Jason Landry
SM BIM-VDC Specialist
Bernhard
