08-16-2018
05:58 AM
- Mute
- Permalink
- Report
08-16-2018
05:58 AM
use the MPROP command and select a single fitting.
Go to the Manufacturing tab.
I believe your fitting has an Insul Spec assigned to it or it is set to "Off".
Set that to "Not Set"
Has to be done one at a time with the method above.
Alternatively you can run a script with the following code and select multiple objects:
item.insspec = "None"
Moving forward you may want to change that setting on the ITM's.
