- Mute
- Permalink
- Report
CAMduct Geometry Under Defined with the Rectangular Trouser
CAMduct Version: 2019
OS: Windows 10
I have a problem with CAMduct that I cannot understand in which manner he develops the flat pattern of the Rectangular Trouser Piece without having sufficient data about where the head point resulted from the intersection of the 2 upper branches will be located.
Problem Type: Geometry Issue (Lack of the needed dimensions)
Problem Description: While trying to sketch the same developed flat pattern from CAMduct using CAMduct inputs in Inventor it fails because as shown below the Inventor sketch is not fully defined and need one extra dimension to be able to locate the head point resulted from the intersection of the 2 upper branches and it cannot be derived from the available inputs.
CAM Duct Developed Draw | Inventor Developed Sketch |
