jazpearson
Are you using Visual Studio?
If so, you can Attach to Process in the Debug menu whilst your application is running. Make sure to pick whatever application you are running, e.g. ESTmep or CAMduct, and also make sure to select managed (4.6...) code type.
Then you can stick breakpoints in your code and you should be able to inspect your objects - although may need to make sure you are running in debug mode.
I'd reccommend looking at the following article for any help:
https://docs.microsoft.com/en-us/visualstudio/debugger/getting-started-with-the-debugger
