MOatman
in reply to: ben
You can use the FILLPOINT command or Multi Point Fill button and route sloping pipe much like you do in revit.
Pick the starting point for the run and then choose the "Elevation" option and enable slope or "Work to Fall" and set the ratio desired.
From there it is point to point with all piping and fittings sloped.
