Hi @andreleslie ,
It sounds like you're having an issue within your visual settings. You could try turning off the related Design Line layers to hide the nodes. The nodes are a part of the Design Line. If that solution does not work for you would you mind sharing your file so I can directly trouble-shoot the issue from my end?
@lindsey.millerJWDVX
Lindsey Miller
Technical Support Specialist
