I am guessing you are using the new CID patterns for the hangers. There is a few bugs with them and this is one of them. You might want to try the old 838 pattern and see if you get anything different.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
