- Mute
- Permalink
- Report
need help with fabrication strut hangers in revit
Hi hope i'm right here.
we using fabrication in Revit for design and pretty much everything works great, BUT for some reason i can't place fabrication strut hangers in Revit over multiple pipes.
I've seen videos were they have done it, but i can't. I can't drag one side of the strut and pull it to the other end of my pipe run.
please help.
Thank you,
Matthias
- Mute
- Permalink
- Report
In plan view, there should be a Node on each rod, grab the node and stretch the unistrut.
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
- Mute
- Permalink
- Report
yes I've seen this, but i don't have this. I can't stretch it. The reason is somewhere in my cad mep set up, but can't find it.
- Mute
- Permalink
- Report
I am guessing you are using the new CID patterns for the hangers. There is a few bugs with them and this is one of them. You might want to try the old 838 pattern and see if you get anything different.
