davidronson
Not sure what you are trying to do. In Fabrication if you want place a fitting in the middle of a run, right click on the fitting and pick Takeoff As Cutin then select the pipe. This insert the fitting and welds necessary.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
