davidronson
Sounds like you probably changed the wrong value. Your weld should have a Product List that contains all the relevant sizes. You will need to change the length of the weld in the Product List.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
