davidronson
in reply to: MaddenDerrick
This is done through connectivity, your pipe connectors should be Male, and the weld connectors should be Female. They also need to be in the connectivity group.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
