463 Views, 2 Replies
05-03-2018
08:45 AM
- Mute
- Permalink
- Report
05-03-2018
08:45 AM
Is there a way to make lines between each item. We are having problems with guys following the hanger cut lists. we would like to add a line between each hanger like an excel spreadsheet.
05-03-2018
09:16 AM
- Mute
- Permalink
- Report
05-03-2018
09:16 AM
It is in the Report Builder. Pick on a field you have added and then look under the Column tab on the right. You need to check "Separate Change in Consecutive Data" option.
Add to as many fields as you like to make it consistently show up.
