338 Views, 1 Reply
How to Splice
We bought autodesk fabrication camduct 2018, and managed to use, but dont know how to splice (when you want to do welding, and it adds a little bit of material, but doesnt change the final form, just helps the welding)
Could you please help us?
Thank you forward
Tags (2)
davidronson
Not sure what you are trying to do. In Fabrication if you want place a fitting in the middle of a run, right click on the fitting and pick Takeoff As Cutin then select the pipe. This insert the fitting and welds necessary.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
