436 Views, 1 Reply
Default margin between nested parts - ceased working
I've only had this software a week or so and I'm getting bizarre issues.
As I'm getting used to it, I'm doing a lot of stuff manually before I start creating this database. Mind you, I'm coming straight int this from PM2000 (1998 BETA). With that said... I go to View -> Properties -> General Nesting tab.
This is where I set a margin for my different thicknesses. I haven't had any problems with it until today. Now, whatever I type in, it doesn't affect the margin around the part at all. I can change the Additional Sheet Edge Margin but nothing I type in to Default margin works. It just stays the same.
Mind you, I haven't changed any settings in Tools -> Setup. Now to screw around, I went in there and tried changing the default margin in the global settings and that changes it on my current nest.
The problem this causes me is that I have different thicknesses of metal, thusly, need to have different margins. When I go to Tools -> Setup, I can only affect it globally, there's no option for me to apply it to a material individually.
Please advise.
