364 Views, 3 Replies
04-04-2018
03:42 AM
- Mute
- Permalink
- Report
04-04-2018
03:42 AM
Diameter Adjustments
Good day,
Im struggling with automatic diameter adjustments. our segment bend needs to slide into the spiral ducts, IE a 150dia bend needs to be 147mm. we are currently doing this manually when entering the size.
I've looked at the Effective Diameter sections under the Fittings Database, also on the connector settings. no where it give me the option of adding a diameter adjustment value. Unless im using the Effective diameter section incorrect.
our segment bend are the CID 51 pattern,
This pertains to all round fittings we use, Reducers, Square to Rounds, 45deg bends, 90bend. etc.
IF someone could help with this it would be much appreciated.
Kind Regards
