nathan.chapman
I don't see you have the option to pick a service.  Is this just missing from the image?  If you see this, does the service have a service template applied?  Does the service template have items associated with it?  Does you Map.ini match your database if things were moved?
Once the database is good assign a GUID to it.  It should then show up in Revit.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
