- Mute
- Permalink
- Report
I got the same problem. However, when I used the Autodesk Imperial, all notches shown on development but then disappeared on nesting.
@Anonymous wrote:I am working with a customer that currently is running Fabrication Camduct 2014, and recently lost the V notches on the Male and Female seams of his fittings when viewing them in Development/Nest Screen/and View NC.
I have installed all of the service packs for 2014, and this did not make a difference.
I have check all of the database settings against a working copy, and they match.
I have also installed Fabrication Camduct 2018 trial, and get the same results.
This is using the customers database. I can use the Autodesk Imperial database and it works, so it has to be a setting in the customers database that I am overlooking. I have tried different V notch depths and angels, and nothing will make them appear.
I can not just use the imperial database, the customer has so many seam and connectors as well as specifications/pressure classes, that it would take days to get all the information transferred over.
I know there is someone that has had this issue before and can tell me what the fix is for it.
