- Mute
- Permalink
- Report
Fab ESTMEP 2018 Pipe hangers not picking the correct Support #1
We have our hangers set up to oversize based on the pipe size. For example, in Item/Edit, under "Name", the 2" hanger will be used for the 1/2", 3/4" and 1" pipe. We have the ID for the 2" hanger for each of these size slots as well, which gives us the correct pricing.
Through version 2016, this worked well. The correct hanger, plus the correct Support #1 (ancillaries) would be chosen.
However, with 2018, some of the ancillaries in the Support #1 is not chosen correctly...there are some ancillaries defaulting to the largest size.
For example, on a 1/2" insulated pipe, we will get a 2" hanger, along with a 2" Protection Shield. (+/- $2) - Perfect
However, on a 3/4" insulated pipe, we will get the same 2" hanger, but it will have a 30" (last size in our list) Protection Saddle (+/- $60) - Way to expensive...why the 30"
For some reason, it is not picking the correct "Insert Type" for the 3/4", even though it is using the same 2" hanger.
Thoughts?
