- Mute
- Permalink
- Report
report showing number of whole pipes
does anyone have a report or linear report that will show how many whole lengths of pipe are needed. I am looking for something like the pipe cut list or bill of materials. when I run a pipe cut list it only includes a list of the cut pieces. I am trying to also produce a list of the other whole pieces that will be needed for the selection of pipe.
- Mute
- Permalink
- Report
Do you want the full sections of pipe to be listed on the same report, along with the short sections? To understand why they are not showing up on your report, we would have to know what properties you have set to filter in your report. Can you please elaborate a little and we can figure out how to fix your issue. Perhaps you could just attach your report in the next reply and I will take a gander.
- Mute
- Permalink
- Report
As far as if it needs to go on the same report or a different one it doesn't matter. if it is on a different report I can run a process to bundle them together. the main goal is a report to express numbers of whole pipe sections that weren't reflected on the pipe cut list. attached is a copy of the pipe cut list report that I use. it was put together by applied software, so I am not sure exactly how it works. any help would be greatly appreciated. thank you
