LanceTSM
You also need to select the option in Database - Fittings - Pattern Switches - Developments - "Cut Insulation"
and tick the box in Auto Nest Dialog - Method Tab - "Nest Insulation Developments"
You should then see your Nested Sheets for the Liner.
