350 Views, 2 Replies
Nesting process for waterjet table in addition to plasma table.
Just added a waterjet table to my inventory of toys in my sheet metal shop, the only thing I see on the screen is the nests for the sheet metal. I am having a really hard time setting up the nest processes for the waterjet.
I assume I should be able to see the nests for the liner on my screen as well.
Any suggestions??
Thanks.
Louis Figueroa.
You'll need to configure an additional machine.
File -> Setup -> Installed Machines
LanceTSM
You also need to select the option in Database - Fittings - Pattern Switches - Developments - "Cut Insulation"
and tick the box in Auto Nest Dialog - Method Tab - "Nest Insulation Developments"
You should then see your Nested Sheets for the Liner.
