- Mute
- Permalink
- Report
Item Product Manufacturer
We have just recently switched to Fabrication 2018 in previous versions there was an Item Product Manufacturer field in the Item information dialogue box that we could edit and we would use this info in our reports. In 2018 I am not finding this editable field now. Is this a feature that was removed or is it just simply turned off and if it is how do I turn it back on? I have attached a screenshot of the field that I am speaking of.
- Mute
- Permalink
- Report
Did you change databases?
That's was added using Custom data. If you're using the same database configuration (you don't typically switch when upgrading software versions) those custom data fields should still be there.
BTW, unless you're drawing with Generic content, your configuration should be puling Manufacturer data from ProdInfo.
