415 Views, 3 Replies
ESTmep join objects when the attacher has been removed
Please help How to join/connect two objects when they have been taken away from the attacher?
lei.qiao
Do you mean that you would like to connect two parts without attacher?
In Fabrication Estmep, if you want to make the layout without design line, workflow is: Add one part and then add the other part with attacher. I think it is hard to connect existing parts.
Go to the 3d Viewer tab. Type "M" for Move. Select what you want to move and move it node to node.
http://autode.sk/2i9hYzf
LanceTSM
You could also try the "Join" Tool
I think it's intended to "Join" items together.
