362 Views, 2 Replies
DXF Export/import
I have a problem in exporting dxf from Cam-Duct.
We opened this dxf file from AutoCad, but curveness is not smooth.
Seems that the curve is consist of less segment.
Is there any advanced setting for this during export or importing?
Mike_Arcari
Use the simplify part option before exporting
this should smooth out everything in to nice arcs
go to - database-fittings-pattern switches and tick the simplify part check box
settings for this feature can be changed from the installed machines setup section or from the profile section in Opus
I have never changed these settings but on 2018 version of Cam-Duct the simplify part option seems to have some serious glitches
2017 version works great
hope this helps
Mike_Arcari
1other thing to try is the number of round sections option
this can be changed from database-fittings-pattern options-number of round sections
you can change how many sections it will split a circle in to from here
