tech3design
341 Views, 0 Replies
MAP Proxy Can't export to IFC without an error message
These MAP Poxy's are evil, that can not be exported to IFC no matter the enabler. see attached file.
I have had the AUTOCAD Fabrication enabler installed. I have even downloaded the AutoCAD fabrication 2018 and still can't create an IFC file. This is very important and I need help with this as soon as possible.
I am using Revit 2016 and AutoCAD MEP 2016 with the fabrication 2016 object enabler installed. I am trying to create a Revit file so I can use Revit Collaboration tap in Revit to upload to BIM 360 Team. I can't use AutoCAD MEP because BIM 360 team doesn't allow AutoCAD file uploaded and linkage in BIM 360 team.
Here is my process-
I open the MEP AutoCAD fabrication file from the Mechanical contractor in AutoCAD MEP with fabrication Enabler. I use proxygraphics command to "1"
then I use the IFC export command and it give me the error.
I need to IFC to create a Revit file to upload and link to BIM360 Team but can't create the IFC. Why?
Is there no one that has this problem? Has anyone run across this problem. Am I just out of luck. There should be a step by step instruction for this. If I get this resolve I will post a step by step to help other with this issue if I find one.
I really need help with this>>>
I can not create an IFC file from these two files.
Where are the experts that can tell me why,
Thank you,
